This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Front camera BUG.
Front camera got ruined by the lolipop 5.0 update.
All the photos got darkened in all modes. I have seen the problem with many of my friends using xperia c3 dual. Please fix the bug.
Camera problem have a solution. do factory reset, and then install camera fv-5 pro, the pictures was awsome. front and rear are fixed, just sony camera had the problem.
