Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
manpreeth
Visitor
ya buddy me too a real die hard fan of sony even i use my laptop also sony ...and theres one more issue with my laptop too after updating to windows 8.1 pro the audio quality reduced drastically and now  this lollipop issue sony will have to close their company
VvkMh
Visitor
IMG_20150426_130837.JPGImage taken by the rear cam of c3 after lolipop update. Just zoom in. Its very irritating to see that.
VvkMh
Visitor
Its one taken by front cam after lolipop update. See, how dark the image is? Its a bright room.DSC_0813.JPG
arp
Visitor
Sony.. Where is the best feature of lollipop I.e. multiuser.....you are making fool of all c3 users...plz solve this problem
VvkMh
Visitor
your cam works fine?
arp
Visitor
No...working but not like previous one
VvkMh
Visitor
Both cams are useless now. Check the photos. Reply if you have the same problem.
arp
Visitor
I don't think I have problems with rear camera but having same problems with my front camera.
VvkMh
Visitor
Even after a clean installation the bug in front cam retains.
Please fix this soon. . .
VvkMh
Visitor
Change your apn settings to gprs access point from wap acces point. May be its the problem
