This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
hi i too got the lollipop upgrade..but after reading the previous reviews people are saying issues with front camera....so did you find that problem? after reading these reviews im scared not to upgrade to lollipop now im doing with my kitkat so shall i upgrade or not please suggest..
this is sick buddy both cams problem ? sony saying that this mobile is a proselfie and if it cannot solve this then its a shame on them...looking forward for a fast fix fo this...
i have mailed many times to sony care asking for lollipop upgrade and what they did is spoil the camera...great...so have you uninstalled lollipop and again installed kitkat?
