The last week my Favourites list under Discover / Guide shows multiple duplicates of some of the channels.
I can't scroll down through some of the channels either - only up.
I have a Bravia 50w809c and the channels are digital..
Hope anyone has a solution.
I've had many more issues, like the TV restarting by itself, crashes... but that's another 10 topics..
Hi Meggamugabe,
Welcome to the community.
It sounds like it might be worth doing a factory data reset. You can read about how to do this here.
Thanks,
Pascale.
Hi
Sorry I didn't report back.
At first, the factory reset fixed the issue. The 2 weeks later, it's back.
It's bothersome having to do a factory reset every 2 weeks or so - I have to spend a lot of time getting the channels sorted, reinstalling and logging in to apps and recalibrating the colors (for every input channel - please let us use a global profile!).. So please try to find a solution on your end, it's a pretty neat feature that I can't use.
I'm including a photo of the problem.
Thanks!
Hi Meggamugabe,
Have you tried manual tuning? (i.e. to disconnect your antenna, start auto tuning, plug the antenna back in and perform a digital auto tune again). This should refresh the signal and hopefully fix the issue.
Win_88
Thanks! I just did a new auto tuning and it helped. Had to sort the channels again, but it beats doing a whole factory reset. Fingers crossed it will stay fine for longer than last time. Thanks again.
I had the same issue and retuning worked. Thanks
Retune helps however after week or so it gets broken again. Anyone has a permanent solution? Retuning takes 30 mimutes to resort the channels...
KX-75XF8596
latest software
version 8.0.0
core 3.10.79
build BRAVIA_ATV3_4K_EU-user 8.0.0 OPR2.170623.027.S34 665751 release-keys
This link should help you check the actual software package version and update to the latest one: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xf85xx_x85xxf_xf87xx-series/kd-75xf8596/d...
