Playstation app part if android 7. 11 upgrade?
SOLVED
xznewbie
Contributor
Hello guys. Just noticed after System upgrades, a Playstation app was installed.. Is this really the peculiarity of the recent update..? If so..Can This be uninstalled.?
1 ACCEPTED SOLUTION
Accepted Solutions
Sant_XZR
Visitor
Hi,
It has been there from 7.0. We cannot
We cannot uninstall it, if required we can disable.
2 REPLIES 2
Sant_XZR
Visitor
Hi,
xznewbie
Contributor
Actually I just noticed after the latest system updates. Anyway I inactivated it do it vanished from the display.
Thanks for your suggestion.
