Hello,
first of all want to say that for all my life i only use sony mobile phones.
I just got XZ and see same problem as i had on almost all android sony phones.
Lagg when i scroll i call menu, when try to search received and dialed numbers.
Everywhere else phone has no laggs but here, its so disappointing that my next phone probably will be from different brand.
Also one more issue. Why when dialing number, it does not auto fill or shows me number what was previously dialed by me but not in phonebook or number was received.
It only auto fills numbers from phone book. This is terribly bad idea to remove this function.
Hi @Chikodol,
Try resetting the phone app. To do this please go to Settings > Apps > 3 dots > Show System > Phone > Force Stop > Storage > Clear Data.
This issue did not start after period of using the phone. That’s how it works from unboxing the phone.
I did reset after your post but it did not fix any of the mentioned problem.
@CameronT wrote:Hi @Chikodol,
Your tips not solved the problem. Freset, flash stock firmware... now chance!
it is a scrolling bug in this app (i logcat with adb and find many error)
The call menu lag is not only XZ problem. Before i had 5 sony phones and all had same problems. All lag when scroll is call log.
For so many years sony could not fix this software problem.
I have never seen this problem in any other phone, even 10 time cheaper samsung does not have this problem.
And, why auto fill option was removed from dial menu? This is stupid and wrong.
I have the same iussue from the beginning.
same problam in safe mode and also during call screen goes black i cant dail number agin
When you say about safe mode, you think it should fix lag? Or auto fill?
If lag no safe mode does not fix it. And i repeat, this problem is on every sony mobile i have ever seen.
If about auto fill.
Auto fill is disabled only on XZ.
On XA it is working as it should. But XZ has no auto fill.
