Hi,
Basically it refuses to connect to PC. It thinks I've connected it to a wall charger because it is stuck in charging only mode. I don't get the box where it says MTP mode PTP mode etc.
I've tried different cables and different USB ports but same result. I also just tried a factory reset and still no luck.
My older Z5 Premium works fine in this PC.
Thanks
Solved! Go to Solution.
Hi Guys,
The problem fixed by its self. I don't know how.
Thanks for your help guys.
Does anyone have any ideas please?
Hi,
Thanks for your reply. Ive tried 3 different computers same result.
It's the same in safe mode.
Does it matter what USB port im using on the PC? I have 6 usb 2.0 ports and 4 USB 3.0 ports. I also have a USB type-c port but don't have a usb-c to usb-c cable.
Is it possible it could be a hardware fault?
