Nougat 7.1.1 rolled out 25.04.17
Dreadish
Visitor
Sony moderators, can u please post changelog of this update. Im reallz in the need too know if this 7.1.1. Improved performance of video playback in the handset.
19 REPLIES 19
Faaja
Visitor
I hoped for repair sound problems but now it got even worse! Sounds disappear like 5-10min after restarting phone + something has gone wrong with video players cause I cant play youtube or messenger videos... Once even camera doesn't work until restart... Any ideas?
GenomeX
Visitor
@Sant_XZR wrote:
Other than round icon, some new shortcuts are available.
That shortcut active when enable developers options and not new
Nearby device active when update google play services.
Igniz
Visitor
Heavy battery drain once i updated to this new version... I used to get 5 hrs SOT. Now its just 2-3hrs sot...
darekesp
Visitor
Me too but on this weekend I do a factory reset and I see what's heppend.
v4l0s
Visitor
Idem. Heavy battery drain after 7.1.1 update on my X performance 🤔
tadfabian
Visitor
I think that with the same daily use I've always done, the battery life is indeed longer.
But what pisses me off is, that my Sygic application doesn't work anymore. I have Xperia X too, still with the 7.0 version, and there works with no problem.
I've tried every idea I had...reinstall, copying data from Xperia X, even factory reset...it still doesn't work....
Any idea what to do?
Jason32473
Visitor
How did you do the update my xz says it is upto date on 7.0?
It's not there anymore..... looks like Sony pulled it back.
Reading trough the forum there was a problem with battery drain.
Sunking1011
Contributor
That has been the case since 7.0
Jrnr
Visitor
I am in the UK, unlocked simfree. Still no update. It has been the case since I had the z1. UK is always the last to get the update 😂,
