How to disable auto correct.
Medoeasy80
Visitor
I need to disable text predictive from my keyboard
I am using sony expira xz
4 REPLIES 4
Emil
Enthusiast
Hi @Medoeasy80,
You can disable the auto correct function in SwiftKey if you go to: Settings > Languages & input > On-screen keyboard > SwiftKey Keyboard > Typing > Typing & Autocorrect > Autocorrect > Off.
Let me know if this helps!
Medoeasy80
Visitor
Nothing change
swemmer
Visitor
mine the same, auto correct off, but still shows
Emil
Enthusiast
I am sorry that I was unclear in my previous post.
Disabling this option will disable auto correction, the prediction bar will still be present. I'm afraid there is no option to disable the prediction in SwiftKey.
