I need to disable text predictive from my keyboard
I am using sony expira xz
Hi @Medoeasy80,
You can disable the auto correct function in SwiftKey if you go to: Settings > Languages & input > On-screen keyboard > SwiftKey Keyboard > Typing > Typing & Autocorrect > Autocorrect > Off.
Let me know if this helps!
Nothing change
mine the same, auto correct off, but still shows
I am sorry that I was unclear in my previous post.
Disabling this option will disable auto correction, the prediction bar will still be present. I'm afraid there is no option to disable the prediction in SwiftKey.
