Android OS using 1,4 GB RAM, is this an issue?
SMRTLim
Visitor
Android OS is taking up half of my RAM usage, I wonder if this is an issue and hoping someone could clarify what's going on?
 And if it helps, my XZ is running Android 7.0, build number 39.2.A.0.417.
Tags (2)
4 REPLIES 4
Lord_viridis
It's fine, mines on 1.3gb and no issues here.
SMRTLim
Visitor
Thanks for the reply, I just want to make sure I'm not the only one experiencing this.
Lord_viridis
No problem, it sounds about right to me tbh.
Sunking1011
Contributor
Mine uses approx 1GB with Marshmallow.
