This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Reintall the update via PCC. My phone works smoothly after the reinstallment.
This morning, when I try to move apps particularly FB app to sd card, the phone rebooted by itself before it can move the app. I tried it a couple of times and it successfully move to the sd card but the phone had some trouble with it and it rebooted 2x during the attempt. The FB app is one of the huge consuming apps in terms of memory and i think due to its several extensions. Does it have something to do with the large amount of memory? Am starting to feel disappointed again.
Also, whenever the app is updating it automatically saved back to the internal storage and I had to move it manually. Is it normal for the app to go back to internal storage after update?
With kitkat the definition of two cameras are not bad, see 1080p in principal and 720P in front camera.
The update to Lollipop this definition crash! I read several articles of this point and in every says what this
is caused by post process in the application. Frustrated and angry downloaded other apps waiting fix this problem, the unique i win is lost the time, the results are equal including cameringo. Please please fix this!
Someone told me the main problem with C3 rear cameras. Apparently the water-colour effect is a result of heavy noise suppresion post-processing, which Sony failed in delivering. Very good sensors but mediocre algorithms. Can the support staff come and validate this?
I seem to have a problem with the C3. Apparently it chases away the mods from forums as soon as someone mentions 'rear camera.' Can it be modified to chase away normal people too?
yes I am having the same issue of noise.
First I thought its becuase of handsfree, but I tried my handsfree with other phones ad laptop. Its working fine.
Noise problem is there.
Hello! Anyone can please help me?
I''m having issues on my phone since the update for 5.0.2.
Apps are crashing. when playing music,it suddenly stops in the middle of the song. whenever updating apps, my playstore stops updating because of insufficient storage when most of my apps and files are stored on my SD card.
What I need to do?
I dont think this SONY staff is going to respond about this issue they are simply concentrating about releasing the new models like C4,C5,M4,M5,Z3,Z4 etc... but not taking interest to solve the camera,lollipo,music issues..im very sick of this SONY stated to hate it... months are passsing on but still there is no proper response in fixing the issues...
OMG is that true ? i thought if i give it to customer service it would be fixed...so even they also cant find a solution to fix this issue ? ridiculous...:smileyshame_on_you:
