This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Yes i do have the same problem for past 4 to 5 months that was so irritating. Still was looking for the updates for walkman app although updated the latest version it still remains the same:smileyangry:
Those bugs with Cameras (bad quality), Calendar (not syncing reminders time), Phone (unable to dial area code 401), GPS (fix time could be 5+ minutes without any improvement) just driving me crazy, really. I am using al of them daily. Gonna sell this just (after 3 month of usage). BOOO!
This is a cropped part from the image taken with c3. Its really annoying to see this pic. Cant even recognize what it is. Please sony.please fix this bug. Suffering very much from this cam bug since I bought this phone. Recieved many updates but none of them rectifies this problem.
I bought my Xperia C3 a week ago and its 5.0.2 out of the box version. I had encountered alreay a couple of bugs.
*Responsiveness - It took 2-3 seconds to launch all apps in the menu when on Simple Home. Chrome & Camera apps takes a while to open.
*Camera Button - The dedicated button does not work properly. Pressing it down and hold dont launch the camera and when using to capture it, it does not work at all if it did takes a while to process photo.
*Freezing - It freezes on me after a couple of minutes after opening the box. Unresponsive apps or sluggish apps. It still do up to this time and I just had to convince myself its worth it. **bleep**!!!!
*Factory Reset - I had to do it 3x already after "Settings" freezes (it will not close and options under settings will not open at all and wifi will not turn off whenever I turn on the wifi when trying to connect to my work wifi network.
*Reboot by itself - It randomly shut off and restart by itself. What more can I say?
Reinstall the latest update with PCC and report back. where are you saving the pictures on an sd card or internal storage?
Bridge (for Mac)
I reinstall the latest version via PCC and looks like the the transition and launching of an app seems smooth. Does the front camera always looks like powdery/blurry when capturing in a low-light? I didn't notice this prior to the reinstallment of the update. Not sure.
