- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia C3 / C3 Dual Lollipop Issues and Feedback
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1st: i cant move apps from internal memory to sd card
2nd: i can't set default of where to install or download new app for either internal or sd card
3rd: wifi connection problem - when running facebook app, it stop to load or stopped connecting. I have to reset (off/on) wifi to resume the connection.
How i can revert the android from lollipop to kitkat on my phone xperia c3?
Or if above problems could be resolve i can still continue the current android lollipop.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Post updating with Lollipop 5.0 I am facing below problems: 1. Mobile become very slow and facing hanging issues. Tried factory reset as well. Still facing the same problem 2. Icons become very large and looks very cheap. 3. Rear Camera blurring issue not resolved and continues in this upgrade also. Have got info that it will be upgraded to lollipop 5.10 in July month. Can you pls confirm if all the above issues will get addressed in that upgrade.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Comparison of GPS performance. Left- Xperia S, right - Xperia C3 Dual with 5.0.1
HORRIBLE GPS performance. Shame on you. Sony people.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Lollipop its quite demanding and the C3 will struggle, if you consider ART standard in lollipop I don't think the C3 can't handle it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hey guys, after the update to 5.0 are you all seeing your device memory as this?
Device memory
Total space: 8GB
Available: 2.48GB
No indication of internal storage at all, does this mean it was merged and therefore usable or is it still separate but not visible? Because I have a game the size of 1.57GB to install.
Edit: My phone is of the 2015 model, so all spaces allocated are 8GB. They actually did the merge!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
before lollipop update sony c3:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
after update to lollipop
