Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
Sasan4797
Visitor
3 days ago I updated my c3 to Lollipop and here is my personal experience on it:
1- RAM issues and suddenly stoping apps is COMPLETELY solved. the device is work great in multitasking.
2- In my opinion, both cameras are improved. (as you see in my previous posts)
4- The time for battery full charging is less than it was before.
5- The battery performance is great. I get 8 hours screen on time.
6. The device works smooth and fine. I like the new UI.
 down side:
1- I can not put the clock widget in centre of screen.
2- the "what's new" widget is not full size.
Sasan4797
Visitor
I strongly suggest you to do reset factory BEFORE and AFTER update. It helps to avoid any lag and bug.
manpreeth
Visitor
Thank you for uploading the pics...But the pics which you have uploaded are they taken in SUPERIOR AUTO MODE OR MANUAL MODE ?
Sasan4797
Visitor
Both pictures have been taken in manual mode.
Bbhadz
Visitor
PLEASE BRING BACK THE IMAGE QUALITY OF XPERIA C3 BEFORE IT WAS UPDATED TO LOLLIPOP. Lollipop cam update degraded image quality, photos looked blurr esp when using front camera.. :'( i really love it's details before..
VvkMh
Visitor
Sony please stop doing this. After the lolipop upadate the camera become the worst. Image quality of rear cam is now below average. The problem while taking videos ie the refocusing problem still there even after the update. Please test your software before making it avaliable for the users. Dont put your customers down. Please. Please fix this as soon as possible.
Karen21
Visitor
I'm gonna go straight to the point,I'm not happy with the Lollipop upgrade in my C3. I am experiencing lag everywhere I go! Messages,Google,Gallery,Camera,etc. I'm not very tech savvy so when I got the update notification I immediately upgraded thinking that this would be a better version,but I was absolutely wrong. I'm so disappointed. It ate a big part of my phone's memory, i needed to delete a lot of apps and even with 1G memory available it still keeps on lagging. WHY?!
I wanna know if it's still possible to downgrade and if so,how?
Will there be fixes? How long should I wait??! HELP! I practically could not use my phone anymore as it's VERY SLOW.
DJonson
Visitor
Another confirmation about calendar issues- wahtever I am scheduling on my computer (Outlook 2013) doesn't sync properly with my phone. Remoneder time NEVER syncing up- I have to manually set reminder time on my phone. Sony-people- it' **bleep**, really **bleep**.
manpreeth
Visitor
phh ok thank you...
VvkMh
Visitor
Anybody suffering from noise problem while listening to music through headset after updating to lollipop? Music player stops after some time.its very irritating. Phone is just an useless thing aftercthe update. What is this sony? Really dissappointing.
