This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
@hwk93 wrote:I got lollipop yesterday. The apps in my sd card just disappeared of the menu. I can open this apps in google play store. The menu says i have 22 apps installed but only show me 17...
bad english...
I suggest you not to install app in sd card. It always gets problem such as widget not found ... etc
If you updated over your previous kitkat intallation, I'd suggest that you do a PC Companion phone repair, this will do a clean installation of the latest firmware and will also wipe your internal memory.
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
http://www.sonymobile.com/gb/tools/pc-companion/
Thats really frustrating my friend...
In your previous comments you have mentioned that you have no issues with camera after upgrading to .472 ..Is the camera working fine ? And now you are saying that SD apps problem....Still is there any other problems ? How about battery backup ? Please reply....Im in a confused state whether to upgrade from kitkat or not...:smileyworried:
This should help you out
http://talk.sonymobile.com/t5/Software-Updates/Lollipop-New-Features/m-p/955490#U955490
Problems with GPS after updating to 5.0.1- navigation became bad (really bad)- losing signal even while standing, open air in the field. I installed app to see GPS settings. Fix time to 6 sattelittes- up to 3 minutes now (after update to 5.0.1).
GPS signal could be lost at any time , every few minutes, recovering in a ~1 minute.
Another glitch with calendar:
1- Create an appontment in Outlook (by copying it from one calendar to another), create reminder
2- Appointment will show on phone's calendar - without any reminder
Calendar/email is Office365 account. No any aother device (Android 4.2.1, windows Phone 8.1) having such issues.
EDIT - any appointmet with non-standard reminder (for Android)- in my case- 1.5 hour. It was working before just fine on this and Xperia S.
