Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
hellohelloworld
Visitor
@Deen-Analyze wrote:
My Xperia C3 Dual after update to Lollipop
- When download app from Play Store , if download to approx. 90% it's will not continue and sometime it's back to "Install" button
- I try reset my phone many time by Sony PCC , Battery still drain faster than Kitkat .
- It's slower than Kitkat
Please fix these issue
Thank you.......
Sometimes, I face the same issue, but I don't think it is because of lollipop update. It may be the server side problem of google play for particular app occasionally. You can try it again later.
I do not have battery drain problem because I turn off all auto-sync, disable google now, turn off GPS........etc. You can google some common ways to save battery. I think if you always use 3g or 4g data, the battery drain much faster than WIFI. By setting 40% brightness and keeping screen on, I can use it for around 11 hours.
Compared with Kitkat, it is quite smooth, I cannot feel faster or slower. I think it should be the same.
Better UI, more free ram is the advantage.
There is no guest mode, otherwise, this update is excellent!
ghazale_seidani
Visitor
Hello dears , i have a xperia c3 .after update to lolipop everything hangs, i cant use camera any way (both of front and back camera) , phone restarts automatically , and i havnt update center! I love lolipop version , please solve our problems by realising another update!
hellohelloworld
Visitor
Delete the cache and data of camera app or try to reset you phone. Some apps may cause your phone restart. You need to take time find it out. Make sure you backup important data first.
Basil-143
Visitor
Hello guys
Hope you help me to get out my issue face by phone xperia c3 dual.Last weeki got a updation from kikat to lolipop frim version 19.3.A.0.72 and i updated my phone NOW I AM FACEING A BIG PROBLEM is my phone drains the battry faster while useing expecaly when am browsing anything when stamina mood is on. The fact is that my power management show a high level of backup on battry of 4day 20hours in 100% battry which drain to 87% within a hour and its made uncomfortable to use my phone on these days
IS THERE SOLUTION TO RECOVER MY BATRRY BACKUP AS ON KIKAT( 1 AND HALF DAY)
Tags (1)
Uliwooly
@Basil-143
Settings  > power management > battery > what is using up your battery?
Basil-143
Visitor
@uliwooly
It only show sum appthat i used frequently like whatsapp 23% which is unbelivable and play store always drains upto 30% every time
And i relaise that my battry is only drain when i use internet even it wifi or 2g/3g its drain faster than kikat and same time power management shows a 4 days and hours of battery backup which lie on me that i cnnt even have a day of battry life
Uliwooly
@Basil-143
check if you are auto updating the apps.
Basil-143
Visitor
@ uliwooly
No i do my best to save battry like off almost every features like auto update and soo on man but still its draining if i on my mobile data option battry drains 1% in 1min
Basil-143
Visitor
No its not updating any app
Basil-143
Visitor
Will please help how to reinstal lolipop in my c3 dual through pc
