Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
rockyrock
Visitor
Front Camera fixed. Battery performance increased A little bIt. Performing better than before.
soegiarto
Visitor
Sony need to fix the icon. I think on lollipop update, the icon now become too large and it's irritating.
rockyrock
Visitor
Camera bug is fixed in latest update
abes
Visitor
I'm willing to update to tha latest firmware .472
Do you asdvice me to do a master reset than update
Or do update than do a master reset
I didnt know exactly what a clean update meant
i am updating wthi OTA in MENA Arabia
s4alon
Visitor
I think if you want to do clean update better to master reset first then update it.
If you don't want to do clean update just update it.
Usually clean update it done if there's a risk of bug after updating.
If not then clean update isn't required
KM3
Visitor
Hi everyone, I am KM. My phone is Xperia C3 Dual but after updating the android to lollipop, I can't use the answerig machine. It kept on saying that the phone has stopped working and could not save the voice I have recorded. Can someone help me fix this? When the android was kitkat, it was working properly.
newo
Visitor
Can I suggest that you add a shortcut key of silent mode,vibration and sound in quick settings menu, it might be easy for us to just swipe down the toogles and press silent mode or sound mode or vibration mode. Thanks.
Uliwooly
@newo
It has been requested before, Sony is aware of this.
Rajesh_Shiva
Visitor
I also suggest place the #close all button in right down corner instead of up where it is now...
Moreover close all button is better in xperia z3 plz do the same for all devices
Deen-Analyze
Visitor
My Xperia C3 Dual after update to Lollipop
- When download app from Play Store , if download to approx. 90% it's will not continue and sometime it's back to "Install" button
- I try reset my phone many time by Sony PCC , Battery still drain faster than Kitkat .
- It's slower than Kitkat
Please fix these issue
Thank you.......
