Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
manpreeth
Visitor
1.)how to dowgrade to kitkat after installing lollipop? cus my friend has upgraded to lollipop itseems same xperia c3....please help
2.) and now u have downgraded to kitkat right? so is the functioning of the mobile same like previous or still any problems u found ?
Tags (1)
Shaun13299
Visitor
Sony will probably solve all these issues in the 5.1 update! I do not recommending downgrading!
WERE THE CAMERA PROBLEMS STARTED AFTER THE UPDATE OR A WHILE LATER? Which region are you from?
ShivaTeja
Visitor
Can anyone help with my internet problem,i am from India
VvkMh
Visitor
I have the same problem. But when I changed the apn settings it was fixed. So I suggested that. For a Bsnl connection there are 3 apns. 1 gprs
2 wap 3 mms. I suggested you to set the acces point to gprs if it is wap.
ShivaTeja
Visitor
No my network was idea it's apn was named as idea internet and idea mms
ssisodia
Visitor
I am also facing front camera issue.. Is Sony going fix it?
VvkMh
Visitor
Dont know. lets keep our fingers crossed.
Shaun13299
Visitor
What is the exact issue with the camera? Please post pictures taken with it or screenshots!
Try using a camera app like the google camera or retrica!
VvkMh
Visitor
I did post the shots earlier.check it in the 3rd page.
Nms1
Visitor
After lollipop update, front camera is recording dull and hazy pictures even in High light. When this bug is going to be fixed?
