This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
I have another problem completely changed all that which I have not received notice of the existence of update
Its just a software update! Not a hardware failure Or defective hardware tht you can go to a consumer court!
Wait for a tweaked update from Sony!
By the way I am not experiancing any issues with the cameras other than them starting slow!
Then you should probably use your Nokia!
Dear Sir,
Recently i have update my sony xperia c3 dual phone from android kitkat 4.4.2 to lollipop 5.0.2. Before update all functions of camera were working good BUT after udpating to lollipop, front camera result is very very bad as photo is came in dark.
please provide the SOLUTION for the above problem as soon as possible sir.
NO i have no problems with the camera! The only problem is that the phone slows down due to heavy RAM usage
I'm not sure if it's present on the C3 but
Settings > users
Hard to say, you could contact Sony directly, but I think it's not included bc of the limited RAM and internal storage on the C3, it only has 1GB of RAM
