Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
Matsya
Visitor
U made my phone after update, what is meaning of asking sim selection every time for a call, why there is not a option to set default sim for call and data. During call in dial pad section there is no delete button to correct any wrong dialing, adding button of add call is foolishness. Walkman doesn't get update, it shows failed to update, also there is no sleep timer in Walkman. In new update 5.0 u have disappeared the most useful TOOLS widget. u thing u are the smart one . U don't give at least basic useful features and make Sony phones dustbin and charging it si costly. Will never buy a phone of your company in future.
VvkMh
Visitor
Dnt be too frustrated man.. .we all are waiting for an update with these bugs fixed. You pointed out some bugs and we all agreed. But Sony is always the best and still I am a die hard fan. These are only software problems and Sony can easily rectify that. But they are very careless on developing OS. I agreed. Hope for a bug free update and be patient. . .k.Thanks
akashcool
Visitor
Bro i understand your problem. if you have, pc install pc companion in it and repair your software. It will work
gius321
Visitor
did you try that? what does repair mean? reinstall KK?
VvkMh
Visitor
I dnt think so.because i did a clean installation by using xperifirm and flashtool.bt it didnt rectify the bugs. So now I am using the same kitkat version. . .waiting for the next update.
hellohelloworld
Visitor
I suggest you upgrade to lollipop again, cameringo lite works for all resolutions. HD camera pro works for 4:3 including flash light. I am talking about the front cam. Tell me your feeling with these two apps. You will be happy with it.
krishnabk
Visitor
Even I have updated my Sony Xperia c3 dual..With android version 5.2,,now the mobile became very slow.. Please suggest me..how to replace older version
Uliwooly
@krishnabk
What do you mean by version 5.2?
soum66
Visitor
How to uninstall the current version?
nitin3034
Visitor
Please don't update please it's the wrost selfie phone now and lollipop update
