Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
gius321
Visitor
Hello, I got the same known problems.
1 Screen Dims And Brightens Automatically
2 Rear Camera Is The Worst + Video
other solutions
3 sound is very bad = disable enchancements like clear phaze and others
4 ram is okay for now = 600 is always in use, i have 100 - 250 free most time (with facebook and other heavy apps i have 80 free)
5 i know that Lollipop update will not be good. do not update ! it may fix camera but other thinks wil get worse
5 and my phone is poor quality built, (meaning external design, feels like it's not genuine)
6 as i know my mobile is certified for United Arab Empires
and do not reply useless post !!! cos i know and you ! know it won't help.
also it like 50%/50% that it can be camera software or hardware problem. i  think it is both ! i many thanks SONY many thanks .
if someone trid other camera apps and picture quality was good then please reply...
sj81
Visitor
Hi
Go for manual setting then activate HDR mode, change resolution....
Shaun13299
Visitor
I have said this before as well! Just try a different camera app! Like the google camera or retrica! The camera app seems to have a bug! Its not a hardware problem! Sony will fix it!
manpreeth
Visitor
I think again SONY will take ages to give the next update....I thank everyone in this discussion forum letting the world know the problems being faced with your devices...based on your reviews and suggestons i havent upgraded to LOLLIPOP and im continuing with my KITKAT and im very much satisfied with..
1.) In the night though there is light and photos taken with flash on rear camera they come little blurred and shaky even with SUPERIOR AUTO as well as MANUAL settings but in the day time both front and rear cameras aesome :smileysmileythumbsup: other than this i didnt find any problem with my XPERIA C3 [ PS :  IM SAYING THAT IM USING KITKAT NOT LOLLIPOP ]
ALWAYS A FAN AND Heart SONY
Shaun13299
Visitor
My photos are amazing as well!
P.s Thats the spirit Face_with_stuck-out_Tongue
gius321
Visitor
I tried many cameras, google camera doesn't work. it's the same... some other cams are better (not proper thought) and video recording is same some of these apps, but i think there is one or two that doesnt' blures videos and records clear video everytime.
other cameras are much better, camera mx, procapture, a better camera ,camera fv 5, DSLR camera
I HOPE SONY WILL FIX IT . i'm so nervous i wanted to kill myself when i realise that camera (why i bought phone) was very bad quality...
and i think sony do not makes very good quality phones which are certified for other countries like arab empires, china , so on...
akashcool
Visitor
Go to service centre and they will repair your software. Hope it works for you.. Good luck guys
VvkMh
Visitor
Did you repair you phone? Have the bugs fixed?
akshiv20
Visitor
Now when I cleared data of simple home it's crashing issue is fixed and my camera works well and takes photos very quickly now in lollipop 🍭 I love lollipop and sony
VvkMh
Visitor
You front cam also fixed?
