Auto restart my Xperia c4 dual when i plough the charger
Hi @Ab108,
Welcome to the community!
If you use a different charging cable, do you have the same problem?
Let me know
Yes
Same problem when i use other cable
I have the same problem,
Please if you solved tell it to me.
Hi @Ab108 and @Sofiane93,
Can you try and connect the charger while your phone is in safe mode and see if you have the same issue?
Let me know
I restarted with safe methode but it don't work, always the same problem
I reset the system too but it don't work
Hi @Sofiane93,
When you say you reset the system, do you mean you did a factory reset?
Or did you perform a software repair using Xperia Companion?
If you have completed the software repair above and still have these issues from here you would need to get in contact with your Local support for further assistance.
Good luck
Same Problem With My phone Since 2 days
