Auto restart my Xperia c4 dual when i plough the charger
Ab108
Visitor
10 REPLIES 10
ChloeS
Contributor
Hi @Ab108,
Welcome to the community!
If you use a different charging cable, do you have the same problem?
Let me know Slightly_smiling_Face
Ab108
Visitor
Yes
Ab108
Visitor
Same problem when i use other cable
Sofiane93
Visitor
I have the same problem,
Please if you solved tell it to me.
ChloeS
Contributor
Hi @Ab108 and @Sofiane93,
Can you try and connect the charger while your phone is in safe mode and see if you have the same issue?
Sofiane93
Visitor
I restarted with safe methode but it don't work, always the same problem
Sofiane93
Visitor
I reset the system too but it don't work
ChloeS
Contributor
Hi @Sofiane93,
When you say you reset the system, do you mean you did a factory reset?
Or did you perform a software repair using Xperia Companion?
If you have completed the software repair above and still have these issues from here you would need to get in contact with your Local support for further assistance.
Good luck Slightly_smiling_Face
Pack1810
Visitor
Same Problem With My phone Since 2 days
Tags (1)
