Hello
my sony bravia will not play movie’s on google play. The app opens and i can pay and sometimes watch trailers but when i try to watch the movie it tries to load then comes back to the google play app.
Clearing cache etc does not work.
the only solution i have found is to disable and uninstall the app. Which then automatically re loads the app at its base un updated state. The movie’s then work perfectly. But after a little bit as it updates Itself the issue will re happen.
so everyday to watch a movie i need to uninstall the app.
is there a solution to this?
the tv has been recently updated but this issue has been happening long before this. Netflix etc all works perfectly.
Sounds like a Google issue more than a Sony one. Haven't found a direct solution so the workaround is all we have rn
