KD-49XE8396 TV. wifi not connected message on screen
farhakhti
Explorer
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Please see the following support article here regarding the Wi-Fi connection.  Let me know how you get on.
Best wishes,
Sean
MaffMaff
New
Hi Sean,
Have gone through all links and checked connection.
Wireless device on TV is found
Local access OK
Internet access OK
Connection method is wifi
All the above found under network status.
Wifi has no internet access though even though other devices are working around it.
3 different BT engineers have no answer. Network is ok as are speeds etc.
HannahEd01
Community Team
Hi MaffMaff , I posted a response on your other comment, let me know if it helped.
farhakhti
Explorer
Yes, thank you very much for clear information, you are a good man
