XZ. Lag in call menu. Also dialing issue.
Chikod
Visitor
Hello,
first of all want to say that for all my life i only use sony mobile phones.
I just got XZ and see same problem as i had on almost all android sony phones.
Lagg when i scroll i call menu, when try to search received and dialed numbers.
Everywhere else phone has no laggs but here, its so disappointing that my next phone probably will be from different brand.
Also one more issue. Why when dialing number, it does not auto fill or shows me number what was previously dialed by me but not in phonebook or number was received.
It only auto fills numbers from phone book. This is terribly bad idea to remove this function.
13 REPLIES 13
CameronT
Champion
@Chikodol,
I wanted to test if the lag issue was happening in safe mode. I don't think it happens to all Sony phones, it certainly doesn't happen to mine or any of my colleagues here.
Please try backing up your handset and running a software repair using Xperia Companion.
minhrauvn
Visitor
I would like to mention: this issue just only happened when we update to Android 7. When I buy XZ, it's still run with Android 6 and Call dialer is ok. Just please check again the call dialer on Android 7 firmware
Chikod
Visitor
Nothing is helping dialer lag.
I had ARC S, C, M, C3 dual, now XZ.
Purchased XA for my wife.
All have and had lag in dialer.
Only sony device i had without dialer lag is Z2 tablet Slightly_smiling_Face
Cant say if it is after android upgrade. First i did after unpacking was android ugrade. So i have no idea how dialer was working in android 6.
What about autofill of numbers in dialer? Any plans to fix this issue?
Bibi678
Visitor
I think the phone book and call list have issues. When swiping up and down is not smooth, Sony needs to fix this for the next update. Thanks a lot
