Water gets through Sony Xperia XZ's gaps between the screen and the frame.
kryptonianguy08
Visitor
Hi all,
When my XZ gets wet, I notice a little bit of water in these gaps (although they don't have any effect on the phone and dry up a few hours later). When I squeeze the phone from the sides and also the top and bottom, the water comes up and then goes back inside. Is this a problem or is it normal?
Thanks.
1 REPLY 1
Lord_viridis
If you suspect your device is letting water inside the actual body, you can contact your Local support and request that the device is tested.
Though I suspect yours isn't actually penetrating beyond the display adhesives.
