Hi all,
When my XZ gets wet, I notice a little bit of water in these gaps (although they don't have any effect on the phone and dry up a few hours later). When I squeeze the phone from the sides and also the top and bottom, the water comes up and then goes back inside. Is this a problem or is it normal?
Thanks.
If you suspect your device is letting water inside the actual body, you can contact your Local support and request that the device is tested.
Though I suspect yours isn't actually penetrating beyond the display adhesives.
