Sort the settings in costum order
SOLVED
fetch93
Visitor
Hello there
I use my phone in the German language. And one thing is annoying me.
Is it possible that we can get the possibilitie to order the settings alphabetical?  I mean not the whole settings I mean the submenu in " WLAN,  Design,  device and system "
The best solution for me is that we can hold one submenu and swipe it on the first place for example.
Exactly like we can do it in the Sony music app Slightly_smiling_Face
This would be awesome.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@fetch93
It can't be done but I'll escalate this, make sure to send your suggestion/feedback to Sony directly as this is a global user based forum >>> Local support
1 REPLY 1
Uliwooly
@fetch93
