Solved! Go to Solution.
I finally fixed it by using Clean Master and using the option Phone Boost. I did it before but forgot to check the box for Android System and/or System UI.
Hi @vallejo08,
Welcome to the community.
I wonder if the launcher is the problem? Can you please test it in safe mode and see if it does the same thing?
which "setting" is "tuner ui"? i have not it on my xz. i have developer options...not your.
I had the same problem. Rebooting normally didn't help, but when booting the phone into safe mode everything worked OK. After rebooting the phone again normally, the problem was gone.
