I got same problem, after I repaired by XC.
The XZ dual firmware version is 39.2.A.0.374
Same here but with Z5 after the nougat update. factory reset, after couple hours just starts again.
Frustrating. phone unusable now. Dont install nougat!!!!
Hi,
after nouget update 7 my xz dual restart alone some times randomly when i downgrade to MM 39.0.A.3.30 the problem gone that mean it's not hardware problem anysoultion?
If you did the upgrade over your old system, it might cause such issues. I'd suggest a clean upgrade by doing a backup using Xperia Companion then performing a software repair using Xperia Companion.
