Hi @Sunking101 and @santhosh20,
Can you please try it safemode and see if the same thing occurs with the default apps, such as Chrome?
I'm facing the same problem i try repair the phone by pc or make factory reset without luck this problem appear after last nogut update,,
I have solved the problem by downgrade to 6.0.1 now no restart so i think it's software problem please fix it sony.
