Phone keeps crashing, as well as apps crashing since Nougat update
BarKohba
Visitor
Ever since I updated my phone to Nougat, I constatly get "app x has crashed"  and the phone keeps hanging and then resetting every once in a while. I reinstalled the software using Xperia Companion Repair, but nothing, I'm getting the same issue.
Anyone else experiencing this?
10 REPLIES 10
adamlee2014
Contributor
Ye I am also experiencing crashes and the phone runs sluggish all the time. I repaired using pc companion, for me marshmallow was way faster and performed a lot better.Screenshot_20161222-124058.png
adamlee2014
Contributor
adamlee2014
Contributor
profile.country.PH.title
MarlonUk1
@92@Vadim_BenKatz: I suggest you to perform software repair using Xperia Companion once more time, but this time do not restore your backup, just observe the phone if the problems occurs,,
you might be expriencing crashes and lags because one or more of your apps are not optimised yet for nougat update,
if the problem is gone, then I suggest you make sure to check each of your apps restored to see which ones are causing the problem
adamlee2014
Contributor
I get system installed apps crash which must be compatible with android 7.0 as they get optimised as soon as you update
joker6310
Visitor
Ever since the the nougat update for xz the phone as been extremely laggy
MarlonUk1
@92, you are using XZ right? as far as I know, Xperia Keyboard isn't available anymore for XZ, that is why it shipped with swiftkey keyboard.
Sunking1011
Contributor
Some of us have sideloaded the Xperia keyboard onto our XZ phones. I *much* prefer it as it sits lower and doesn't obscure the screen in landscape (with all auto-correct features disabled), plus I can type faster and more accurately with it.
adamlee2014
Contributor
Yes I'm using Xperia Keyboard
