Hi! After updating to Nougat 7.0, in my contacts app I've noticed a big annoying Glich.
After the letter Z, a # is shown and "Unknown" contacts are in that menu. If I keep scrolling down there's like thousands of it. I provided a picture for proof.
Solved! Go to Solution.
@TomaszTGM Make sure you have a backup of your contact then go to settings - apps, tap on 3 dots and show system. Look for contacts storage and under storage tab, clear data. This will remove all the locally saved contacts.
