as the sony staff said, they already are investigating this, they fixed the sensor fail on xperia X performance with a software update, we'll hopefully receive the same treatment, after all we use the flagship device...
I have the same issue.
Interesting enough, see if you guys can give this a try: turn your phone upside down and double tap the screen.
Odd enough, this has worked for me 90% of the time. I'm curious to know if there's a bug in the software logic that and the sensor reading switched.
Went back to the store today and got a new XZ because "double tap to wake" didn't work (but "double tap to sleep" worked every time).
The new phone is working better with "double tap to wake" but it doesn't work at all with "double tap to sleep".
How can it be?
39.0.A.1.250 on both.
What's going on?! Is it a hardware or software problem? Should I go and change this phone as well?
I can't believe Nougat update dosn't fix the issue. it's either sony still hasn't learnt about the issue or it's hardware fault.
I had the same issue with my xz, until I read on one of the other threads that if you do the double tap slower it will work, I found it works every time now
Anyone has managed to slove the issue (after update)?
