Hi I just got my Xperia XZ last thursday. Im so excited because I had a bad experience in my Z5 Premium Dual that has a heaphone jack port issue.
When I open the box and boot the phone everything is fine. After few days of using it, I suddenly notice that the double tap to wake up is not that responsive. I have to tap more than 3 times and faster so that the phone can detect my tap. Tap to sleep works fine, though.
Can someone from Sony clarify if this issue is a software issue or a hardware issue? Atleast, users here may have a reference whether to wait for a software update fix from Sony or send the defective unit to the local repair shop.
I think this is the least thing that Sony representatives can do here. Not mentioning, that it is already an inconvenience from our side because this is a brand new premium phone and it shouldn't be like this.
I hope we could get answers at the earliest. Thank You.
hey all ,
same issue here from UAE , I bought device before 2 days ago , screen look like "frezing" when I want to tap it as double click ,some time working after 3 times or more ! also when the screen on I cant close it by the same way (double click
Also , it has poor network reception , is it that normal ??
I did the factory reset , still the same issue !
I think this is hardware problem
sorry for my language that so weak >
Can you try the solution that Sunking101 suggested. Try to uninstall xperia lounge and see if it works.
