How do you double tap to wake?
I've noticed that X & XZ reacts diffrently compared to the Z series.
I can double tap to wake Z series in any situation (in hand or laid on table)
While for XZ it works 100% in hand, but there are some missing out when laid on flat surface.
Same here, my XZ is pretty impressive so far after using for a week.
But only thing is the double tap to wake not working.
Maybe only 1 out of 10 times trying worked.
I have a Screen Protector come free from local Sony distributor by the way..
same, my double tap is not working properly.
i have to tap more than 10 times for the phone to wake.
after wake, the touchscreen work perfectly and diagnostic also works.
so i think is software not detecting the double tap all the time.
Oh I found the problem with mine, now it's working properly just like Z series, I had Stamina ON.
With Marshmallow, Stamina has issue with double tap to wake because Doze cut the screen standby mode for double tap to work to save battery.
Try it and give us a feedback
