Can't save pictures on SD
Jose30
Visitor
My xperia xz was working well but for some reason I try to update my apps now and they go into a endless updating cycle    also when I take a picture to save into the SD card, it says picture could not be taken   anyone having this problem?
2 REPLIES 2
profile.country.PH.title
MarlonUk1
1. regarding app updates, are you on the latest google play version? try to clear data of the app. settings>apps>(app) >clear data, restart your device
2.) try to boot to safe mode, and take a picture. does it work?/
it seems that your sd card might got corrupted somehow. can you try to connect it to a pc. ?
Jose30
Visitor
Sadly I don't have a pc and my laptop doesn't support the xperia companion thing     support told me that it's a glitch in the update    everything from Google play Store is up to date and some apps already got updated by force    as far as pictures I switched to internal memory and when  I try to move apps from phone to SD card it just gets stuck
