Call and SMS notifications won't play
Mebs
Visitor
My phone won't play any notifications when I receive a text,  neither will it play any ringtone when someone calls. It works well after a reboot,  but only for a few minutes.  I tried a hard reset and even factory reset but the same thing happens, it'll work for a few minutes and stop eventually .  I have Checked all the settings to make sure notifications are turned on.
Please help
6 REPLIES 6
profile.country.US.title
Qatrium
Hello @Mebs and welcome to the community!
Can you reboot your phone in safe mode and check if you get the same issue? Use the blue link for a guide.
Mebs
Visitor
Thanks @Quester.
My phone is currently running in safe mode,  I'll have to observe for a few more hours.
But what next when I find that the notifications continue/discontinue  to play in safe mode?
Qatrium
@Mebs
If the issue disappears in safe mode, this means that one of your installed apps are causing it. As safe mode will disable all 3rd party apps. You'll have to figure out which app is acting up by uninstalling one app each time and testing (tedious), or by performing a software repair using Xperia Companion and re-installing your apps one by one.
GenomeX
Visitor
Please help
Okey, check this path
Settings>Apps
1st click on 3dot icon and select "show system"
Now, click on gear icon and go to advanced category and select "special access"
Now click on "Do not disturb access"
See any app manage do not disturb function?
Now go to Settings>Lockscreen & security>Apps with useage access
See any third-party apps (no system apps) is listed and permission activeted?
If yes, turn one of them and test the problem is solved? If no check other one and...
If notification solved, means you find the app break your notifications.
Mebs
Visitor
@ Quester I at least have established that a third party app is the cause.
I haven't however managed to find out which one it is exactly.
But thank you very much.
Mebs
Visitor
@GenomeX my phone says "no installed app has requested for do not disturb access"
Also I have toggled the settings under 'apps with usage access'  and the notifications still won't play
