Alarm problem
SOLVED
baris2840
Visitor
Alarm problem
I set my alarm to 7.30 am but clock widget shows 00.00, but after 00.00 widget shows 7.30. How can I solve it?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
@baris2840 There is a 3rd party app acting up. Any battery savers or cache cleaners?
alexdon
15 REPLIES 15
_alexdon_
@baris2840 Have you tried to add the widget again? You can also try settings - apps, look for clock app, tap on storage tab. Clear data. This will remove your alarms.
alexdon
baris2840
Visitor
Yes i tried all of that and didn't work
_alexdon_
@baris2840 Have you tried to boot in safe mode and set your alarm from there?
alexdon
baris2840
Visitor
There is no problem at safe mod but when I reboot it's same again
_alexdon_
alexdon
baris2840
Visitor
I have AVG cleaner
_alexdon_
@baris2840 Try to remove it for a short period of time and see how things are.
alexdon
baris2840
Visitor
I removed AVG cleaner but nothing changed, it's still same
profile.country.US.title
Qatrium
@baris2840
Try this:
- Go to Settings -> Apps -> tap on the 3-dots icon on the top right corner -> Show system -> Clock widgets -> Force stop, then go to Storage -> Clear data and restart your phone.
