DAB rewinding/jumping forward
mlsk67
I purchased a XAV-AX1005DB which was fitted into my 2007 Golf. Whilst listening to DAB radio, it cuts out as the audio rewinds a second or two then does the same but jumps forward again. It’s connected to the front screen DAB aerial.
Is there anything obvious I can do to fix this?
Thanks
 Martin
2 ANTWOORDEN 2
Anonymous
Niet van toepassing
Hi @mlsk67
Did you make sure that its firmware is up-to-date? https://www.sony.co.uk/electronics/support/mobile-cd-players-digital-media-players-xav-series/xav-ax...
Also, you might need to check the aerial, or its connection to the unit
Check page 24 of this guide: https://www.sony.com/electronics/support/res/manuals/4740/cdd8bee9454f27801a7ca44b873f9cda/47408931M...
mlsk67
I did, that’s always the first thing I do. I’ll check out your link about the aerial, thanks.
