I noticed that there are 3 USB connection types on the Xperia X: charging, MTP and MIDI.
What is the MIDI connection used for?
Solved! Go to Solution.
Use USB to
Use device as MIDI
Use device for musical instrument apps (MIDI input)
https://developer.android.com/reference/android/media/midi/package-summary.html
Use USB to
Use device as MIDI
