Hi @Abdullah4,
I'm sorry to hear about that, it does sound very strange.
When you reset the phone, did you perform a software repair using Xperia Companion or was it a normal factory reset from Settings > Backup & reset?
If you go to Settings > Apps > tap on "All apps" > Disabled, are any of the apps that are missing in this list?
If they aren't, I would recommend that you perform a software repair using Xperia Companion. This will delete all data on the internal storage in the phone so it's advised to backup using Xperia Companion before starting with the repair.
Let me know how it goes!
Hi again!
This error message will be displayed if Xperia Companion detects that the device's software has been modified in some way, not necessarily rooted only. Have you perhaps unlocked the bootloader on your device?
Keep me posted!
Hi again!
I'm so sorry for the late reply.
This is being looked in to and I will update you as soon as I have received more information.
I'm sorry for the inconvenience.
Hi again!
Have you managed to repair the software in your phone yet, or are you still receiving the same error message?
Let me know if it worked to repair the software and how it works after that!
