- Als nieuw markeren
- Bladwijzer
- Abonneren
- Dempen
- Abonneren op RSS-feed
- Markeren
- Afdrukken
- Ongepaste inhoud melden
december 2016
december 2016
Hi
I just arrived in Australia, but I'm not getting mobile data.
I tried downloading APN settings (Settings - More - Internet settings) over Wi-Fi, but it still isn't working.
I suspect the APN settings are wrong, but there's no Access Point Names setting to check. (It should be under Settings - More - Mobile networks, but the only option there is for data roaming -- that's enabled).
Any suggestions?
Any suggestions?
Opgelost! Ga naar oplossing.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
december 2016
december 2016
It's a US SIM, and yes, they support roaming data.
After I got the Nougat update yesterday, I now have the APN settings menu, and was able to get it working.
2 ANTWOORDEN 2
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
december 2016
december 2016
are you using a local sim? or the simcard you have at your home country? have you contacted your network if they support roaming data?
how about when you try to use a local simcard?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
december 2016
