- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
December 2016
December 2016
Hi
I just arrived in Australia, but I'm not getting mobile data.
I tried downloading APN settings (Settings - More - Internet settings) over Wi-Fi, but it still isn't working.
I suspect the APN settings are wrong, but there's no Access Point Names setting to check. (It should be under Settings - More - Mobile networks, but the only option there is for data roaming -- that's enabled).
Any suggestions?
Any suggestions?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2016
December 2016
It's a US SIM, and yes, they support roaming data.
After I got the Nougat update yesterday, I now have the APN settings menu, and was able to get it working.
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2016
December 2016
are you using a local sim? or the simcard you have at your home country? have you contacted your network if they support roaming data?
how about when you try to use a local simcard?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2016
