I have just purchased a PCV-RXG408. Can any body tell me how to fix a SCSI Host Adapter into this machine. The manuals that came with the machine don't even tell you how to open the side/back covers!
Cheers
Blond.
Hi,
Normally you just get a PCI card which can do scsi, Adaptec does one along with Promise. You plug in the PCI card carefuly and start up Windows, it should be detected. Install the drivers and now you have SCSI abilities.
If I remember correctly, there is a very small section in the manual which tells you what bits you have to press/remove to take the covers off
Page 77 and 78 to be exact :!:
Thanks guys/girls!
