Hello @ all,
some days ago, i buyed a Vaio Notebook and installed SUSE 9.1 (Linux) as second OS.
Now I´m serching Driver for the modem and the Display.
Do you know where i can get this?:smileyconfused:
There is good news and bad news....
There is a driver for the modem, but its gonna cost you, search in google under linux and conexant, there is a free driver but it only supports 18 k or something rediculas. Once you have your modem working zip over to the ATI web site and download the relevent tar ......:smileyhappy:
best of luck
i have instal the video drive from www.intel.com for intel 82852/82855 GM/GME bat without effect
then i have installed the 1280patch.c and execute on boot time
the firt time manually update XF86Config like XF86Config-4 with 1280x768
see this link
http://translate.google.com/translate?hl=it&sl=en&u=http://kurumi.sakura.ne.jp/~chimari/TR2/index-e....
Luciano
