Hi there,
I just got my A117s and god damn it's nice..
But i've got a problem, or I dont know if its a problem but it keeps writing charging 100% if i look a power options .. What to do about this ?
Sincerely
Mads
There's nothing wrong with that, once it gets to 100% it will simply run off the AC even though the status message doesnt change. Or you could just take the battery out when it's plugged into the wall.
It's a peculiarity of all Vaios that I've ever used. The battery does stop charging, it juust doesn't let Windows know. There is an explanation at http://www.vaio-link.com somewhere in the knowledgebase.
You have nothing to worry about, hope you are enjoying your new A117S
