Closing my shutter
jamesrowland
Visitor
Closing my shutter
I have a PCV-RZ104 and was wondering if these new Sony Wireless cards would be able to fit in the PC-Card slot of my desktop and then allow me to shut that compartment. It's really only for aesthetic reasons, and as I now have a BT Laptop Adapter would the range be any different between the two.
Cheers,
James
1 REPLY 1
iainjturner
Visitor
The larger the antenna on the card, generally the better the signal is, although it also depends on the quality of the card, thickness of the surrounding objects, interferance etc.
